Pushing my 2600k past 5ghz
christee66
* EDIT to add bencharmark
So i got bored and decided to try to push my 2600k past 4.5ghz last night. It Took me a while but i am up to 5.0ghz and been stable so far. 5.0ghz was my goal and i am happy to have hit it :). I would like to share my settings and ask for any feedback and/or tweaks. I realize these settings will likely degrade my CPU and i don't care. It is not an everyday clock i just wanted to try to push as far as i can for benchmarking. If my CPU burns out i will have a reason to upgrade my chip and board. My last test of prime small ran for 1 hour without fail. I stopped it there. Had a max temp over the 1 hour of 81 with average temp of 76 - 78. You guys think i should push farther or leave it alone and benchmark it?
My rig
Motherboard - Asus P8Z68-V PRO/GEN3
CPU - Intel i7-2600k @ 5.003ghz (102.1x49)
Cooler - H100i GTX push/pull
Other cooling - 1x 200mm fan, 1x 140mm fan, 8x 120mm fans (including rad fans)
Ram - 16gb Corsair Vengance, low pro
GPU - MSI GTX 970
PSU - corsair TX850m
Case - NZXT Phantom (original) with some customization
Now on to my BIOS settings
BCLK freq - 102.1
Turbo ratio - All cores (@ 49)
Internal PLL overvolt - Enabled
Mem freq - DDR3 1633mhz
Load Line Calibration (LLC) - extreme (100%)
VRM freq - manual - 500
Phase control - Extreme
Duty control - Extreme
CPU current capability - 130%
CPU voltage (vcore) - 1.450 v
DRAM voltage - 1.50000 v
VCCIO voltage - Auto
CPU PLL voltage - Auto
PCH voltage - Auto
DRAM data ref voltage on CHA A - Auto
DRAM ctrl ref voltage on CHA A - Auto
DRAM data ref voltage on CHA B - Auto
DRAM ctrl ref voltage on CHA B - Auto
CPU spread spectrum - Enabled
DRAM primary timings - 9/9/9/24
CPU ratio - 49
Speed step - Enabled
Turbo mode - Enabled - Auto
Thermal monitoring - Enabled
Hyper threading - Enabled
Limited CPUID max - Disabled
Execute disable bit - Disabled
Intel virtualization tech - Disabled
Intel speedstep tech - Enabled
CPU C1E - Disabled
CPU C3 report - Disabled
CPU C6 report - Enabled
Well there you have it. Any comments or tweaks anyone can think of feel free to post. Im not sure if i want to try to push any further at the moment yet. But if i do i will let you know.
If you're just benching, no harm in pushing the core speed a bit more. Doesn't have to be completely stable for benchmarking, just has to finish the run ;)
Stability-wise, sounds like you're at a good spot if prime's okay for an hour. I wouldn't want to run it at 1.45V if it were my chip, but if you're okay with degrading it :shrug: Personally, I'd rather sell it and upgrade for cheaper rather than kill it and upgrade at retail.
Nice job :thup:
