Hi guys,
please help me with my fan that i pulled from the mining machine Antminer S4.
So the fan is working in the Antminer but i can not start him with external power 12V5A and external PWM controller that i bought from ebay. I tried every possible wire connection but nothing happens. Once just spinned only one circle . I dont know the pinouts but here are the specs from this fan.
https://bitmain.zendesk.com/hc/en-u...n-specification-and-possible-replacement-fans
original Antminer S4 fan spec:
Dimension: 120*120*38mm
Voltage: 12V
Start voltage: ≧8V (Power ON/OFF)
Power consumption: 1600RPM 1.68W / 4000RPM 25.8W
Rated current: DutyCycle 100% @ 2.15A
Air Flow: 4000RPM @ 178.3CFM (Max be 239CFM)
Noise: 4000RPM @ 56.7 dB-A (Measured in a Non-EchoChamber)
Air Pressure: 1600RPM 2.88 MM-H2O (4000RPM 16.9 MM-H2O)
Life Expectancy: 40,000 hrs @ 25℃ (May degrade faster at higher temperature)
Connector: 2510-4P
and i bought this pwm controller
http://http://www.ebay.com/itm/201075407376?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thanks in advance
Voltage: 12V
Connector: 2510-4P
Thanks in advance
