OceansCrashing
- Mar 3, 2018
I understand (or at least think I understand) the inclusion of molex on pumps is done so you’re less likely to plug a pump into a hub and over-burden a header causing a fire hazard.
If Im using a powered fan hub with a separate molex power connection, is it generally ok to eliminate the molex connector running to the fan, and instead merge the four wires into a single four pin fan connector?
