Once i have flashed beta bios(when i had p35c-ds3) and i only have troubles with it..so i do not recomend to do it....Has anyone tried the newest F11 bios for ep45-ds3r from gigabyte?I don` know if i can flash it because it`s beta.Please answer.Thanks.
The MAX cappabilities of the Q6600 Vcore Voltage limit is 1.5v I really wouldnt surpass that even on water like me.... you should hit higher specially with that board. its a nice board certaintly better than what I got.... GL
First off let me state I'm not an uber clocker, nor have I been very active as of late.
Idle or load voltages- Mainly I go with load, but running dc projects I'm usually at full load or off.
Start with the Overclocking sticky at the top of the page. Here's an explanation of the other voltages,http://www.ocztechnologyforum.com/forum/showthread.php?t=40747. Like was mentioned, try to get the other voltages off "auto".
IMO, you get the other voltages figured out, you should be able to drop the vcore. I haven't run my vcores that high, as my temps usually went nuts long before that. (4 sticks of ram might not be helping you either, but get it stable, cooler,lower then you can look at that)
Not all of the q6600's are going to hit 3.6 and be happy. I've had 3, and only 1 would hit that, even then it was set for 3.4 for 24/7 use (temps)
I've worked with a few different q6600's, I would say with your chip you should aim for about 3.4ghz as close to 1.4V as possible. That was the sweet spot for a couple of my chips, voltage ramped up considerably for speeds higher than that. At that kind of voltage, I've seen degrading on q6600's, so you would likely lose your overclock over time anyways.
Also, consider running your ram at 2.1V if you're planning to clock higher than 800mhz. Most 800mhz ram will do close to 1066 at 2.10V if they're good chips. Even if you're not overclocking, you can experiment with a slight voltage bump, one of my installs needed this to remain stable.
Robust Graphics Booster ..............: [A]
CPU Clock Ratio ......................: [8X]
x Fine CPU Clock Ratio................: +0.0
CPU Frequency ........................: 3.6GHz( 450x8)
********** Clock Chip Control ********
>>>>> Standard Clock Control
CPU Host Clock Control................: [Enabled]
x CPU Host Frequency(Mhz).............: [450]
PCI Express Frequency(Mhz)............: [100]
C.I.A.2...............................: [Disabled]
>>>>> Advanced Clock Control..........: [Press Enter]
CPU Clock Drive.......................: [800mV]
PCI Express Clock Drive...............: [900mV]
CPU Clock Skew........................: [ 0ps]
MCH Clock Skew........................: [ 0ps]
******** DRAM Performance Control ********
Performance Enhance...................: [Standard]
(G)MCH Frequency Latch................: 333
System Memory Multiplier (SPD)........: [2.00B]
Memory Frequency(Mhz).................: 900
DRAM Timing Selectable (SPD)..........: [Auto]
****** Motherboard Voltage Control ******
Voltage Types..........Normal...........Current
>>> CPU
CPU Vcore..............1.27500V.......: [1.5]
CPU Termination........1.200V.........: [1.38]
CPU PLL................1.500V.........: [1.61]
CPU Reference..........0.760V.........: [.914]
>>> MCH/ICH
MCH Core...............1.100V.........: [1.4]
MCH Reference..........0.760V.........: [.914]
MCH/DRAM Reference.....0.900V.........: default
ICH I/O................1.500V.........: [1.570V]
ICH Core...............1.100V.........: [1.200V]
>>> DRAM
DRAM Voltage...........1.800V.........: [2.00V]
Everything else auto or default
