- May 31, 2004
If I read this article correctly, Anantech has shown that the QX9650 can achieve 3.0 ghz putting out only 44 watts on full load when adjusted for the lowest possible stable voltage. If we can extend that result to Q9450's, then it seems a significant advantage over the Q6600. Low voltage and reasonable OCs may make the Q9450 a king after all.
The 24/7 power savings over 3 years might well pay for the up front cost differential; plus you get a bigger cache, more efficient processing and SSE4.
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3184&p=2
Can anyone reproduce the 44 watts result with a Q9450? I assume you will need a power meter.
