- Nov 26, 2005
- Concord, NC
88c with prime95 smallFFT on water with only 1.36 Vcore??? Something is NOT right.
Where did you read water? I thought he had a Vendetta 2.
Try the heatsink thing,like has already been mentioned. Once you are confident that you have you cooling the best it's going to get, then settle in for your Prime 95 runs.
Don't be hesitant to play with the HSF a little, larger fan, rotate the orientation, check the base. (does the side off the case improve temps?) What are your ambient temps like? I had one Xigmatec that the base was just a tic lower than the heatpipes, thus the heatpipes weren't making good contact. That one little ridge was good for 5c.
One core being off, no biggie. I've had 3 and they all did that.
Prime 95, personally I'll run it for 18-24 hrs on small ffts, then run it on the blend test. Even if you run one of our DC projects and your cpu is under full load 24/7, don't be surprised if temps drop 5c from your prime tests.
FWIW, above 3.8ghz on my q9550 took "fine tuning" of the other variables/voltages. I don't remember what ones, it's been about a year.
That is some solid volts there my man... Hopefully the load temps dropped to reasonable levels as well.
Thats really what matters. So long as she is around 72C or so, that will be fine. Again, congrats, nice o/c at nice volts!I will get the full load temps posted this evening.
Wow, you've got a nice overclock there. I hope I can do as well next week. What cooler and what case are you using?
OCZ Vendetta 2 and an Antec three hundred. I am also using OCZ Freeze thermal grease, very good stuff.
The CPU/FAN sit directly under a top mounted 140mm fan. I have the Vendetta2 turned so that the exhaust faces directly up into the top case fan. The HSF is probably 2-3 inches from the top case fan.... So in theory its kind of an unofficial push/pull system. The heat from the CPU immediately gets vented out the top.
Antec 1200 case
I use a tuniq tower extreme 120 im at 1.29vcore @ 3.901..
I idle at 23c and load at 37-43c
I hate my motherboard and ram so im stuck at 3.9
http://img210.imageshack.us/img210/8484/26563380.jpg
