- Aug 5, 2011
- Toronto, Ont.
Hey guys.
First time on here and first time in the whole overclocking scene and I seem to be having problems. I was told to Overclock my q9650 from it's stock 3.0 to 4.2+. Problem i'm getting is that I cannot get it above 3.6 stable for some reson. Like I said I'm new at this and there for most likely doing something wrong. If anyone can help me out aht would be great.
The settings i have in bios right now are:
Cpu Ratio Setting: 9.0
FSB Freq: 400
pcie Freq: 100
fsb Strap: Auto
Dram Freq: 1066mhz
Dram Timing Control: MAnual
Cas# Latency: 5 Dram Clocks
Dram RAS# to CAS# Delay: 5 Dram Clocks
Dram RAS# PreCharge: 5 Dram Clocks
Dram RAS# Activate Precha: 15 Dram Clocks
RAS# to RAS# Delay :AUTO
ROW Refresh Cycle Time : 50 Dram Clocks
DRAM Static Read Control: Disabled
Dram Read training: Disabled
MEM.Oc Charger: Enabled
Ai. Clock Twister: Moderate
Volatges:
Cpu: 1.34375
Cpu Gtl Voltage Ref(0/2): .635
Cpu Gtl Voltage Ref(1/3): .625
Cpu pll Voltage: 1.56
Fsb Termination Voltage: 1.36
Dram Voltage: 1.96
NB Voltage: 1.40
NB Gtl Ref: .635
Sb Voltage: 1.10
Pcie Sata Voltage 1.50
Load line Calib: Enabled
Cpu Spread spectrum: Disabled
Pcie Spread Spectrum disabled
CpuClock Skew: Normal
NB Clock Skew Normal
Cpu Margin Enhancement: optimized
Those are all the setting I have changed not sure if they'r good or not.
Lastly my system specs are:
Intel(R) Core(TM)2 Quad CPU Q9650 @ 3.00GHz (4 CPUs), ~3.6GHz on Corsair H70 Water Cooler
Asus P5Q-Premium
4gb KINGSTON HYPERX KIT 2GB DDR2 1066MHZ
Hd 6970 2gb+ Hd 6950 2gb in Crossfire
Corsair HX750Watt PSU
Samsung f3 500 gb Hard drive
Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1
Thank you in advance for any help.
FSB Freq: 400
pcie Freq: 100
fsb Strap: Auto
Dram Freq: 1066mhz
Volatges:
Cpu: 1.34375
Dram Voltage: 1.96
NB Voltage: 1.40
NB Gtl Ref: .635
Sb Voltage: 1.10
Asus P5Q-Premium
