- Sep 22, 2010
- Maryland, USA
:::::::::::::::::UPDATE 6/16/11:::::::::::::::::::::::::::::::::::
Leds installed. pretty much done
:::::::::::::UPDATE 6/14/2011:::::::::::::::::::::::::
latest pictures of the build. Dual loop installed with the XSPC dual mcp35x. leds are only thing thats left.
Long time viewer, first time poster.
First off, I'd like to say thank you all for the knowledgeable posts I've been reading to start this project. I am building a fully internal water cooling setup inside my HAF 932. There will be one loop to the CPU for now. I have already purchased parts and installed the quad radiator inside the top of the case. All it took to fit the radiator inside the case was the removal of a piece of sheet metal via Dremel. While my case is stripped, I am going to paint the inside primer black.
Water cooling parts list:
Case: Coolermaster HAF 932
Rad: Swiftech MCR-420 QP
Fans: (8) Coolermaster R4 in push/pull @1000rpms
Fan Controller: NZXT Sentry LX
Pump: MCP350 12 VDC pump
Pump top: Laing DDC pump clear acrylic
CPU block: Koolance CPU-360
Reservoir: Swiftech MCRES-Micro rev 2 w/ Phobya temp sensor
Tubing: Masterkleer 1/2 ID clear
Fittings: Assorted 1/2 ID fittings with zip ties as clamps
Fillport: Danger Den
PC parts list:
Mobo: ASUS crosshair IV formula
CPU: AMD 1090t x6
RAM: OCZ gold 1600 4x2gb
GPU: Asus AMD Radeon HD 6970 w/ Arctic Cooling Accelro Xtreme Plus
PSU: OCZ Fatal1ty 750w modular
Fans: Coolermaster (1)230mm + (1)140mm
LEDs: NZXT 24" sleeved LED string
HDDs: OCZ Vertex3 120gb, Western Digital Black 1tb, WD Green 2tb
Pictures as on 5/15/11
PC parts list:
CPU: AMD 1090t x6
