- Aug 12, 2002
- Chicago, IL
How much more seti are the quad cores pumping out than the dual cores?
What OS is being used for the quads?
Thanks!
Thanks!
none1 said:So if a quad is around 4500 rac ... how much is a dual putting out?
I'm Intel stupid nowadays - isn't the E4300 and E4400 the same CPU with a different stock multi, which can be changed? If so, I'll look into putting together a cheap-o C2D instead of a 939 next time. If I can manage 1800 RAC for near the same money it's worth it.muddocktor said:For the Core 2 Duals here is what I can get:
E6600 at around 3325 gets around 2550-2600 RAC
E6300 at around 3450 gets around 2500 RAC
E4400 at 2500 gets around 1800-1900 RAC
T7400 laptop at 2166 gets around 1500 RAC
