My budget Work/Gaming PC
ASUS P8H61-M LX Rev 3.0
Seasonic 520w powersupply
Intel I3 -2100. 3.10Ghz
250gb WD sata hardrive
Not that tech savy, at this time but
a)
RAM Question.
is it useless to put
dual
CORSAIR Vengeance 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M1A1600C10B
or
dual
Corsair Vengeance (Dual) 2x4gb ddr3 1600 CL9 (CMZ8GX3M2A1600C9)
bec my motherboard memory is limited to
ASUS P8H61-M LX Rev 3.0 Specs:
2 x DIMM, Max. 16GB, DDR3 1333/1066 Hz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* The maximum 16GB memory capacity can be supported with 8GB or above DIMMs. ASUS will update the memory QVL once the DIMMs are available in the market.
* Refer to www.asus.com or user manual for the Memory QVL (Qualified Vendors Lists).
* Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Install a 64-bit Windows® OS when you want to install 4GB or more memory on the motherboard.
b)
I am Planning to buy a PowerColor HD7870 GHz Edition 2GB GDDR5 -seen this... Min PowerSupply : 500w
can my motherboard work on this video card
Link for ASUS P8H61-M LX Rev 3.0 specs:
http://www.asus.com/Motherboard/P8H61M_LX/#specifications
Note: I am not a hardcore gamer. Just want a good gaming pc and a work pc.
pls reply
thanks
a)
RAM Question.
dual
or
dual
b)
pls reply
thanks
