- Aug 10, 2010
- Sunshine State
EDIT
Here's the deal...
I have some old HW just collecting dust in a closet right now and since I'm planning on joining the benching team I figured I could put them to some use...
I'm not home right now so I can't be 100% sure of the model numbers, but I know I have:
- Intel P4: I would have to look at the markings on the CPU to make sure which one this is... All I can remember now is that it came off of a Dimension 8300 that I thrashed a few months ago. It was single core with hypetrheading; and I think it was rated at 3.2GHz... I'll take a look at the model and ratings when I get home from work tonight.
This one is:
Intel P4
630 SL7Z9 COSTA RICA
3.00 GHz/2M/800/04A
3503A892
- Celeron: Same deal as above; only this on is still sitting insde a GX60 that I've had for a long time as well. Will also take a look at the model/markings on this one later on.
This one is:
CELERON
2.40GHz/128/400
SL6VU MALAY
Q437A315
My questions:
- Socket? Same for both? 478? or 775?
- Worth OCing/Benching?
- I have the MoBo that holds the celeron, the other one was thrased.... Are both the same socket? Can I use that one MoBo with both?
- That MoBo is one of those that Dell ships with their PCs so the BIOS is rather limited... I guess I'd be better off buying a MoBo that allows the "good" options... Any recommendations?
That's it for now... Thanks
Sebastian
Here's the deal...
This one is:
Intel P4
3.00 GHz/2M/800/04A
3503A892
This one is:
CELERON
2.40GHz/128/400
SL6VU MALAY
Q437A315
My questions:
Sebastian
