Hi All,
I'm admittedly new around here so I apologize if this is in the wrong place, but I had an idea for a project, but then couldn't find the information to see if it would work anywhere. I've been eyeing the Corsair 680X case, but admittedly don't love the 3 fans up front look. I still want the RGB to be useful and visually interesting so I had the idea to replace the glass with a piece of white acrylic cut to the same dimensions to fit in its slot as I believe that it should (at least if buying the right type and thickness) diffuse the light from the fans behind it.
Thing is I've never toyed with acrylic for light diffusion. I see it for sale on that, but I haven't seen it used much in computer cases and haven't been able to find any specific examples of how it might look. The case comes with Corsair LL120s there, and I also have a set of QL120s that I could use, which do give a lot of light but I don't want to invest money in case and acrylic to find out it won't work. So I was hoping someone around here might have experience with it.
One last idea I had with it, if anyone can confirm the above, would be to cut or chemical etch a design into the back (the side facing the fans) of the acrylic panel and if that pattern would show up on the other side when illuminated. I figured that would be the step above sort of cool value to this mod if it worked...but again I'm kinda in the dark on this.
Thanks for any help that can be provided!
