I've read some conflicting things on the net so I thought I'd ask here.
First off I was wondering if anyone could tell me if there is a difference in RAM between different CPU? I was intending on taking RAM from my gigabyte p55 USB3 i7 870 1156 set up and using it in a ASUS expert i7 4770k 1150 build.
Can I do this or will I need to purchase different RAM modules? Is there a difference between RAM of different generation CPU?
I was intending on using the same Router and RAM for this new build. Can you suggest how I can make sure that everything is clean and wiped of data etc and any potential virus before I use it in another computer build.
I want to make sure that if I do have a hidden virus I won't infect the new build? It makes me sus that I no longer can set a password in my router or update/downgrade it's firmware. Has anyone had this happen?
