this...I'm pretty dern sure that gabe wouldn't make a product like that.I cant see any reasons why you cant run push/pull on that rad?
The front fans are only about 3 or 4 inches away from the front of the rad. I have to believe that their gonna do something
Oh and this rad doesn't allow for a push/pull
the problem is that it comes with 8 screw hole on each side. the holes to mount 4 fans if u choose. but if u mount 4 fans u have no holes to use to mount it with. unless i can drill into the side, but the problem is i dont know how far i can go before i hit the radiator fins
...You mount the fans to the case
You should put your pictures inline, once you upload them, just click the arrow indicated below and you can manipulate them like any other photo post, but with attach tags instead of img tags.
That's gotta be the 6th time I've seen use that picture lol. Keep up the good work
And good job on your first w/c setup, looks nice. Thermaltake isn't really known for making anything good, and I doubt their fans are anything special. If I were you, I'd gut the 4 fans you have on that rad now, get some longer machine screws that pass through 2 fans, use the 4 gutted fans as shrouds and mount some yate loons on there. but thats just me
