webmedic got me thinking yesterday. I had all the pieces needed to put together a kyro/res. I already had the heat sinks and 120watt peltier screwed together. Which made it a relatively quick job of setting up the resivior.
I used one of those weatherproof boxes you get Home Depot to setup the RIO 120gal/hr pump and pelted heatsink.
To be honest, I didn't think this was going to work at all. I had discussed chillers with tril0byte close to a year ago and he did something like this with bad results. But for the system I am testing with, its performs very well.
AMD [email protected]
Ambient temps are 20c
Idle temps 32c via monitor and 27.6c with external probe by the core.
Full load temps 34c via monitor and 29c with external probe.
Ambient temp 20c
Idle temp 34c via and 29.3 with external probe
Full load 36c via and 30.4c with external probe.
The fan on the heat sink for the pelt is extremely quiet and low cfm. Heck this is the first time I have ever heard my hard drives it is that quiet. This is not a bad setup for the size t-bird I am using. But I don't think this kyro/ res could step up to base cooling a high power overclocked, overvolted cpu. Still turned out to be a fun project and another one watercooled.
Ambient temp 20c
