- May 4, 2011
Current RAM: Corsair XMS2 800mhz CL5's 2x2GB
CPU-z Data:
Memory tab:
General:
Type: DDR2
Channels#: 2
DC Mode: Symmetric
Timings:
DRAM Frequency: 400 MHz
FSBRAM: 1:1
CL:5
tRCD:5
tRP:5
tRAS:18
tRFC:42
CR:2T
Is there anything wrong with this setup? Is it running at true 800 Mhz?
This section is what confuses the hell out of me.
SPD Tab:
Memory Slot Selection: 1/3(both are the same settings.)
Module Size: 2048 Mbyte(same)
Max Bandwidth: PC2-6400(400MHz)
Manufacturer:Corsair
Part Number:CM2X2048-6400C5
Correction:None
Timings Table:
JEDEC#1
270MHz
4.0
4
4
13
15
Blank
1.80V
JEDEC#2
400MHz
5.0
5
5
18
22
Blank
1.8V
Settings set in bios are:
DDR2 800MHz
5,5,5,18
2.1 V
Is there something wrong with the settings that doesn't show the memory running at 800 MHz in CPU-Z? Also, I experience a certain memory bug(Memory loop.)It clogs up, then says "Not enough memory to start Application." The only fix is to restart the pc. any insight? could it be bad settings on the RAM?
CPU-z Data:
Memory tab:
General:
Type: DDR2
Channels#: 2
DC Mode: Symmetric
Timings:
FSBRAM: 1:1
CL:5
tRCD:5
tRP:5
tRAS:18
tRFC:42
CR:2T
SPD Tab:
Correction:None
Timings Table:
JEDEC#1
270MHz
4.0
4
4
13
15
Blank
1.80V
JEDEC#2
400MHz
5.0
5
5
18
22
Blank
1.8V
DDR2 800MHz
5,5,5,18
2.1 V
