Hello.
Been a while since i last posted anything now, and my memory (brain) is somewhat gone astray.
I'm starting to get a bit insterested in OC'ing again, and I'm looking for spot to have them 24\7. GPU will be pushed hard.
I had my RAM sticks clocked to about 3Ghz "stable" for a very long time (6-7months), and i started getting bluescreens while doing random things.
I went back into BIOS and simply tried turning off my OC (RAM only) and my problems stopped. Bluescreens were rare, but annoying as hell when untimely.
Yesterday i decided to crack the case open, clean fans and all that. Set up new profiles for cooling etc..
Now I want to get those sticks running back up at 3Ghz (29XX) and if i recall correctly, my last OC with them ran at 1.240V (standard is 1.200). Tried upping them to 1.280 to avoid any bluescreens.
Worth noting: Sticks passed multiple torture tests in Prime95, Memtest etc with 1.240 last time, but seems to be the cause of bluescreens still?
Bottom line question might be: What Voltage would you give my sticks (look in signature) to run 24\7 on 29XX Mhz?
I'm not going to play with timings yet.
