gingerjesus
- Aug 16, 2015
Hi everyone - I'm having fun with first time overclocking and have got a pretty stable setup going, but I have some questions regarding RAM that I have assumptions on based on a lot of forum research but have yet to find definitive answers on.
Setup : Motherboard Asus M5A99X EVO R2.0 ; CPU FX-6300 ; Ram Kingston Hyper X Fury 1600 4GB x2
The Motherboard ram specs are the standard 1333,1600,1866 etc.
Questions :
1 - I've increased FSB to 241 which, in BIOS, is giving me selectable RAM MHZ settings of 1,284, 1606 (current setting) and 1928 and so on.
The first question is - are these odd clock speeds ok ? So far I haven’t noticed any instability at 1606 (although there was at 1928) after some quick Prime tests and 3 hours of Witcher 3 at Ultra, but not sure if I’m hampering the system in any way.
Because if these random clock speeds are ok, then ….
2 – What’s with the 1333,1600 standard speeds ? Are they just for easy marketability ? Why would a motherboard not just say e.g. “compatible up to 1900 Mhz”
3 - CPU-Z shows the DRAM frequency at 806Mhz which is reasonably correct for 1606, but Windows (10) Task Manager has the RAM speed at 1333Mhz on the Performance tab. I assume this is ok and I can ignore Task Manager as it’s just an indicator based on standard speeds and not a true speed (Note if I drop the FSB back to 200 then this setting in bios puts the Ram speed at 1333).
4 – CAS Latencies and timings – are you able to just trial adjust these willy nilly ? The Hyper X is rated at 10,10,10,13 at 800Mhz and 9,9,9,27 at 720mhz. For the sake of argument, am I able just to keep the speed at 800Mhz but try changing the timings to 8,8,8,25 or am I completely missing something here ?
Cheers ,
GJ
Questions :
Cheers ,
GJ
