- Jan 5, 2004
- Denver, CO
So this has come up quite often lately with the release of SATA-2 and 16MB 7,200 drives plus the addition of NCQ. Well lets put this question to the test, and see if we can't come to a conclusion shall we?
Goal: To determine what drives are best for you. Taking cost and performance into consideration here we will see what is the best bang for the buck, and which drive performs best.
Method: What i did here was take 2x74GB Raptors in a RAID 0 and 2x250GB Hitachi 8MB drives in RAID 0 and tested them in the same system using identical Windows installs. To get the most accurate results i ran each test 3 times and took the middle result to give the most accurate run. I rebooted and defragged between each test. I used Windows XP x64 Service Pack 1 for these tests.
Test Setup:
DFI NF4 SLI-D 6/23-2
AMD X2 4400+ @ 2800MHz
2x512 OCZ Gold VX PC-4000
Sapphire x850 XT Cat 5.7
PCP&C 510 Deluxe SLI
Zalman Air Cooling
2x74GB Western Digital Raptor 10,000 RPM 8mb Cache SATA
2x250GB Hitachi T7K250 7,200 RPM 8mb Cache SATA-2
Both on Nvidia 64k Stripe
Cost:
Using the latest prices from Newegg.com:
WD Raptor: $186.00ea
Hitachi: $123.00ea
WD Raptors for RAID: $372.00
Hitachi's for RAID: $246.00
Price per GB:
Raptor: $2.50
Hitachi: $0.50
As you can see the Raptors are WAY more expensive per GB making them not economically sound to some. Lets find out if the price is worth it.
Results:
Atto:
HD Tach:
Test Setup:
Zalman Air Cooling
Cost:
Hitachi: $123.00ea
Price per GB:
Raptor: $2.50
Hitachi: $0.50
Results:
Atto:
HD Tach:
