- Mar 30, 2003
Can RDRAM make a comeback?
http://www.aceshardware.com/
RDRAM could make a surprising comeback, thanks to SIS. SIS and Rambus launched today the SISR659, a chipset that is capable of using 4 (16 bit) 1200 MHz RDRAM channels. When you do the math you'll see that those four RDRAM channels can deliver no less than 9.6 GB/s (4 x 2 bytes x 1200) to the chipset. Of course, this awesome amount of bandwidth is going to be bottlenecked by the 800 MHz FSB of the Pentium 4. To get better performance out of the otherwise wasted bandwidth, a Dynamic Look-ahead Cache and Adaptive Page Management can be found within the R659 chipset. The Dynamic Look-ahead Cache Intelligently prefetches data into an on-chip chipset cache, and lowers the latency of the memory subsystem. Normally, a pagehit on a well-designed DDR 400 controller like the i875p results in a 5 cycle latency: 2 cycles through the controller, 2 cycles for the CAS latency (assuming CAS = 2) and 1 cycle back through the controller. The look ahead cache reduces this to two cycles. If a page hit does not occur, PC1200 RDRAM should have a latency that is very similar to DDR400. Rambus and SIS claim that the latency of the RDRAM channels vary between 10 (cache) and 35 ns, while DDR400 memory latency should vary between 25 and 35 ns. A few benchmarks (source: Rambus), R659 versus i875P (Dual DDR400, 2-3-3-6) Quake 3 fastest: 7% faster Return to Castle Wolfenstein: 7% faster Content Creation 2003: 3% faster SpecViewperf PRoe: 12% faster SpecViewperf DRV-09: 9.5% faster SpecViewperf UGS-03: 3% faster Seems pretty good, but I think the real power of the ASUS board can only be unleached by the overclockers community. The ASUS P4S13G board has two 32 bit RIMM sockets which have to be populated by two 1200 MHz dual channel (2x16 bit) RDRAM RIMMS. The board is also equipped with 3 SATA and 3 PATA IDE connectors. The ASUS board that will be coming out in the next weeks, has the option to use a 800 MHz FSB/PC800 setting. Simply overclock the FSB and keeping the mem in sync should give some pretty good results. I am betting it will come close to 1200 MHz FSB given the right CPU, based on my previous experiences with ASUS RDRAM boards. Samsung seems very enthusiastic and claims that by Q1 of 2004, 75% of their RDRAM chips will capable of 600 MHz DDR or 1200 MHz, with another 10% hitting 800 MHz DDR or 1600 MHz.
