Hello all, been stalking around here for tips for a few days, but this is my first post. Nice community you have here and lots of great information so thanks for that! On to my question, Using MB M.I.T on my Gigabyte GA-970A-D3 -- AMD 970 MOBO I've upped my FX 4100 to 4.2ghz and the Vcore automatically set itself to 1.47. The following screen cap is @ 20 hours on blend torture testing in prime95. This seems to be pretty stable, and the max CPU temps are @46/47c, which seems pretty low, even for a liquid cooled system. This is my first custom built PC and I wanna squeeze as much out of it as I possibly can without sacrificing MOBO/chipset life expectancy too much. So my question is, does anyone else around here have this same chipset/MOBO that has safely pushed it farther? If so what settings are optimal, and finally, is there any more risk/benefit to upping the FSB instead of just CPU Freq/Vcore? Thanks in advance.
As for the crazy high temps in the second set of figures there I had a second Radeon HD 6870 in there previously that has a locked up cooling fan and it was removed prior to this testing run. I don't know if the MAX column reflects all time for the program's logs or if it only reflects the most recent powering up of the system but I hope to god that it's a lifetime log ;;
