- Nov 26, 2002
- Jersey City
So, time for me to build a new machine. Will primarily be a gaming machine, but I will also likely be running a Plex server on it.
Looking at getting a GTX 1080 and a 4k monitor and need some help with the specifics.
For the CPU, would it be worthwhile to wait for the Broadwell-E release since apparently Intel is making 4 versions, two of which will be on the cheaper end ($400-$600) or should I just go with a 6700/6700k?
Any recommendations for which mobo to go with(obviously depends on CPU and I would prefer one that supported DDR4)?
I am also looking at getting an M.2 SSD for the system drive. Looking at the Samsung 512GB right now. And I will also be getting a standard HDD for extra storage.
PSU suggestions? Keep in mind I will almost certainly not be adding any other big power draw components(would just upgrade rather than going SLI and I have a NAS, so I won't need more HDDs).
My other question is the monitor. I definitely want a 4k monitor, but the issue is that I want one in the 30"-34" range and the options there seem very limited. I have tried a 37" 4k monitor at work and it is just too big to use. For me, 32" or 34" seems to be the sweet spot. The cheaper Asian brands (like Yamakasi and Wasabi Mango seem to only have 28" and then 40" or larger). Given this, I have it down to these 4, but would be open to other options:
Dell UP3216Q
Acer Predator XB321HK
Samsung U32E850R
BenQ BL3201PH
Currently leaning towards the Acer Predator, but can certainly be convinced otherwise. The BenQ has the benefit of being ~$300 cheaper, though it only has HDMI 1.2. That shouldn't matter as I can just use display port.
Any help is greatly appreciated. Thanks.
Dell UP3216Q
Samsung U32E850R
BenQ BL3201PH
