- Mar 26, 2008
- Northern NJ
This is my first post on here for quite a while (wife and I welcomed our first baby 5 months ago, so hobbies went on the backburner).
So on to my question. I recently purchased a 47inch 1080p LG Scarlet TV and decided to set up a HTPC to accompany it. I am essentially going to use the components listed in my sig for the pc, just rebuild it in a HTPC case with additional accessories as BD, IR, etc...
I have been doing quite a bit of research of different components and front ends, but I have hit a complete snag with one thing, and can't find a solid answer really anywhere for it.
In short: Is it possible to record cable HDTV broadcasts on a home-built HTPC?
To clarify, I'm wondering if it is possible to access my cable's HDTV channels and record them to my HDD. Currently I have a DVR provided by the cable company, which in fact does use a cable card. I just can't seem to find a option (if at all possible) to make my HTPC able to record it.
I'm not sure if this helps, but my cable company (Cablevision) has all of the HD channels located in the 700 range.
Any help / insight would be greatly appreciated. I have a bit more research to do in regards to final specs and the build but this topic I just couldn't find anything solid on, so I figured I'd come to you guys.
Regards in advance
-Evo-
EDIT: Within reason, I have no problem purchasing the needed hardware (ie: a certain tuner card that allows this functionality). I also don't have any access to antenna HDTV broadcasts... being in a condo complex sadly I am stuck with cable only.
Regards in advance
-Evo-
