I am planning to build up a rig with this specifications:
intel core i7-5930k 6 core 3.5GHz
Motherboard Asus X99-Deluxe LGA 2011
Asus Strix GTX980 4GB
G.Skill 32GB(4X8GB)
My friend has bought the same rig with NZXT. H440 for the case. However the case is sound proof, there is still lots of fan noise. I wonder if you could suggest me a way to reduce the noise as much as possible, as it is really annoying for working long hours. I appreciate your suggestion for any case model or solution overall.
G.Skill 32GB(4X8GB)
