I just recently expanded my loop by adding a 120.4 rad, a DDC 3.25 pump and a GPU block. This is in addition to an existing 2 year old D5 pump and 120.2 rad.
I added the second pump in series because I was concerned flow would be reduced with the new block/rad but most because I wanted some redundancy.
This new pump is loud. Probably not many db, but a high pitched sound. It runs at about 4500 RPM @ 12V. Reducing voltage reduces the pitch of the sound, but makes it louder. I have run the pump between 12V and about 8V (where it stalls) with less pitch to the sound but it gets increasingly noisy. I am using a fan controller to do this.
I have run the pump in my hand, so I can eliminate vibration resulting from installation.
Any ideas of how to tame the noise from this pump?
Its driving me crazy
