- Sep 13, 2015
I found this http://www.performance-pcs.com/mayhems-xt-1-nuke-coolant-concentrate-1l.html#Specifications and this http://www.performance-pcs.com/mayhems-silver-coil-99-999-pure-fine-silver.html I figured that would cover all the bases. I hate automotive glycol. It's a pain to clean off and I'd have to get it off the hoses and radiator. And my hands, and my sink. LOL
If you are willing to invest the money into the fluid it is probably a lot easier. As for the silver coil, the fluid already contains a biocide and the coil should not be necessary and could possibly cause problems in the system. You could also consider the EK fluid like this one http://www.performance-pcs.com/ek-cryofuel-clear-premix-900-ml.html but that mayhems should be fine as well as long as you are sticking with the clear fluids.
