Has anyone here ever re-flowed a DIMM? I've re-flowed Xboxes, PS3s, video cards but never a DIMM.
By the process of elimination I believe its a bad solder joint on one of my DIMMS.
System:
MSI 68-G43(G3) (with Ver. 5.0 BIOS update for Ivy Bridge Support)
I5-3570K
Patriot Viper Red Dual Channel 2 x 4GB 9-9-9-27 1600MHz
EVGA GTX-570
Cooler Master Extreme 2 Power Plus 625W
Using MSI Genie OC BIOS setting
Elimination:
1. Power Supply - All Voltages excellent
2. Computer Boots up every time with the good 4GB DDR3 stick in any DIMM slot
3. Computer will cycle through start up/shut down every 5 seconds with no post when:
5. Performed several memory tests after twisting and getting the bad stick to work. Mem86+, and some others reported NO errors.
So does anyone else think I've tried it all and it sounds mostly likely to be a bad solder joint on the DIMM?
Thanks for any feedback!
System:
I5-3570K
EVGA GTX-570
Elimination:
a. bad stick in any slot
b. good stick and bad stick in any slot variation (tried them all)
4. I give the BAD stick a gentle twist and it starts working for a day or 2 in any combination of slot positions with or without the good DIMM.5. Performed several memory tests after twisting and getting the bad stick to work. Mem86+, and some others reported NO errors.
