- May 19, 2006
- Mother Russia
In the end, its just a longer shroud but made out of metal instead of plastic.
thideras said:I would not buy that version, I'd just drop my card in my loop...lower temps and easier for me.
nd4spdbh2 said:ya but i dont see how i could really remove all that much heat.
piotrr said:Exactly. That's what I'd like to see, see if there's any visible reason for it, if there's anything to be learned from looking at the deconstructed shroud.
The difference hasn't been large in any of the relevant reviews, but it seems to me to actually result in a 3-4C difference, and a very small OC headroom as a result. I'm not sure. I'm not convinced. I'm not going to pay cash money for sheet aluminium attached to a plastic stock cooler. But I would like to analyse it.
nd4spdbh2 said:they probably just made the stock fan run at a higher duty cycle... most 8800gts's from EVGA come @ 60% duty cycle... they probably just flashed it to 75-80% duty cycle and put on a different shroud, and make 80 dollars more for the same card... quite genius i might add... but if i were u just get the base model of what ever ur looking at... not the superclocked or KO or ACS3 ones... because the base model like my evga 8800gts 640mb with stock clocks of 500/1600 ocs to 630/2000... which almost all 8800gts's top out at no matter what... pluss the stock cooling with stock thermal paste has done me quite well... temps never get over 65*C with the fan @ 60%
