I've been reading a lot of the build threads and question and answer threads and I was thinking about the significance of reservoir placement.
Some thoughts that I had:
What else needs to go on this list? Agree or disagree with any of these points?
- The top of the water level must be above the intake for the pump. An easy way to accomplish this is by placing the reservoir above the pump but if for aesthetic reasons you want to have the pump horizontal or in another position the water level in the reservoir must be about an inch or so higher than the intake of the pump to allow for turbulence in the reservoir.
- Loop order generally does not matter for cooling, but it does impact the ease of removing air pockets from your loop. If the top of the reservoir is the highest point in your loop, it will be somewhat easier to remove the air from your system. The alternative is to do some serious tilting of your system, running it on its sides, etc.
- The orientation of the reservoir should be considered when tilting the system (I call it burping for those of you that have had kids). You do not want the pumps to pull in air when you tilt your system.
