Hola,
It's been about 10 years since I last did a WC rig... Just getting that out of the way... My last setup was with a Swiftech WB, d-tek pump & 120mm rad, + home depot tubing so my knowledge of current cooling is pretty limited.
That being said I realize modern CPUs run considerably hotter and require a much higher end system to OC. Talking with my brother (and raiding his spare parts) I have enough to cool my machine... short the waterblocks. The problem I’m running into is deciding between the two setups I have parts for.
Setup #1 would be pure DC powered, and require me to upgrade my PS. It would be a single 120mm rad, with a decent pump, and fit 100% inside my case.
Setup #2 would be pure AC powered using dual high-flow two 120mm rads, monstrous pump, and require some creative bolting to the side of my case.
I want the setup to be nice looking, but at the same time allow for a whole system WC. (CPU, GPU, Chipset etc) I need some advice on what setup to proceed with, and what WB’s seem to yield the best results. I’m hearing Swiftech is still a great option for blocks, but I’m having a hard time finding a good one for my video card.
Any advice would be appreciated.
Asus GeForce GTX460
AMD Phenom II Black 560 (AM3)
MSI 870-A G54
xClio Windtunnel
Just for S&G here’s my last attempt at WC and case mod. I was 19 leave me alone.
Asus GeForce GTX460
MSI 870-A G54
xClio Windtunnel
