- Nov 21, 2005
- Atlanta, GA, USA
I'd like to thank MSI for letting me test this board.
Specs.
CPU
• 64bit AMD® Phenom II CPU.
Hyper Transport Bus
• HyperTransport 3.0 supporting speed up to 5200MT/s
Chipset
• AMD® 790GX and SB750 Chipset
Main Memory
• Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600* (OC) SDRAM, 16GB Max
Side Port Memory
• DDR3 SDRAM 1Gbit
Slots
• 1 mazarine PCI Express x16 slot with x16 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 light-blue PCI Express x16 slot with x8 operation (PCI Express Bus SPEC V2.0 compliant)
- When 2 PCI Express x16 slots are all installed, the PCIE x 16 lanes will auto arrange form x16/ x0 to x8/ x8. Do not use the light-blue slot when only one PCI Express x16 card is installed.
• 2 PCI Express x1 slots
• 2 PCI slots, support 3.3V/ 5V PCI bus Interface.
On-Board IDE
• One IDE port by AMD® SB750
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• 5 SATA II (1~5) ports by AMD® SB750
• 1 eSATA port by AMD® SB750
- Supports storage and data transfers at up to 3Gb/s
RAID Function
- SATA II 1~5 support RAID 0, 1, 5, 10 or JBOD mode by AMD® SB750
Audio
• Chipset integrated by Realtek® ALC889
- True Blu-ray Audio Support
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Realtek PCI-E GbLAN controller 8111DL
- Integrated Fast Ethernet MAC and PHY in single chip
- Supports 10Mb/s, 100Mb/s and 1000Mb/s
- Compliance with PCI-Express Bus specification v1.0a
IEEE1394 / FireWire
• Chipset integrated by VIA® VT6315N
- Transfer rate is up to 400Mbps
Internal I/O Connectors
- ATX 24-pin power connector
- ATX 4-pin 12V CPU power connector
- CPU x 1 / System x 3 FAN connectors
- CD-in connector
- Front panel audio connector
- Front panel connector
- Chassis intrusion switch connector
- 3 x USB 2.0 connector support additional 6 ports
- 1 x Floppy disk drive connector
- 5 x Serial ATA II connectors
- 1 x ATA133 HD connectors
- Serial port connector
- Clear CMOS button
- Power button
- Reset button
- OC switch
- 1 x IEEE1394 connector support additional 1 port (optional)
- 1 x TPM module header (optional)
Back Panel I/O Ports
- 1 x PS/2 keyboard or mouse
- 1 x 6 in 1 audio jack
- 6 x USB 2.0 ports
- 1 x RJ45 LAN jack
- 1 x optical SPDIF-out port
- 1 x eSATA port
- 1 x DVI-D port
- 1 x Graphic Card port
- 1 x HDMI port
- 1 x IEEE1394 port (optional)
Now for some photos.
Specs.
CPU
Hyper Transport Bus
Chipset
Main Memory
Side Port Memory
• DDR3 SDRAM 1Gbit
Slots
On-Board IDE
On-Board SATA
RAID Function
Audio
LAN
IEEE1394 / FireWire
- CD-in connector
- Clear CMOS button
- Power button
- Reset button
- OC switch
- 6 x USB 2.0 ports
- 1 x RJ45 LAN jack
- 1 x eSATA port
- 1 x DVI-D port
- 1 x HDMI port
