Hello all, Im 99% done deciding what to put into my new computer apart from the heatsink/Fan!
This is my rig that i will be building when i find out what cooler to get. Few things that might help, dont have AC in my room so want something that will help keep my CPU cooler. Limit is around $90
Can only buy what is listed in these two shops
http://www.scorptec.com.au/computer/10/46
http://www.pccasegear.com/index.php?main_page=index&cPath=207_23_845
Also was thinking of removing the stock fans from either "Noctua NH-U12P SE2" or "NZXT Havik 140 CPU Cooler" and adding 1 or 2 Scythe 120mm Ultra Kaze 3000rpm Fan Then i would add GELID PWM Y-Cable(If i read/understood things correctly, will reduce the sound when the fans aren't needed) Is that correct??
Have read that when the NZXT Havik 140 is running both stock fans it makes a strange sound.
CPU:Intel Core i5 2500K
Thermal Paste: Arctic Silver® 5
Motherboard: Gigabyte GA-Z68X-UD3R-B3
Memory:Corsair Vengeance 8GB
Hard Disk(SSD):Corsair Force Series 3 60GB
Hard Disk #2:Samsung 2TB Spinpoint F4 Eco Green
Hard Disk #3:Samsung 2TB Spinpoint F4 Eco Green
Case:Silverstone Raven RV03 with Window
Optical Drive:Samsung SH-B123L
Power Supply:Seasonic - X-650
Graphics:MSI GTX 570 Twin Frozr III PE/OC
Thanks again!
Thanks again!
