Hello,
I'm testing a new step in my computer OCing (config here after).
It's 100% stable exept if I use the restart computer button (stop and start works perfectly). In that situation, windows XP shutdown the computer but it doen't restart. My MSI K7T266 Pro leds indicates that it blocks during the RTC (Real Time Clock) test.
Does any overclocker met such a problem ?
Config:
- MSI K7T266 Pro 1
- AMD XP2000+ Palomino
- multiplier x13 in stead of x 12.5
- FSB 133/266
- 1 Go DDR PC 3200 (400 MHz) works well as you may think
- Windows loaded in DDR (register modification)
- DDL purge when leaving applications (register modification)
(the two previous works perfect with OCing x12.5 and FSB 137/274 or no ocing)
Thanks for help!
Config:
- MSI K7T266 Pro 1
- FSB 133/266
Thanks for help!
