Are you sure it's in all the way? you better check againya, when i plugged mine in, i made SURE they were fully seated. The click wasn't enough, i got up close and personal to verify the plug couldn't go any further hehe
You need another GPU like you need another hole in the headNo, but if you like, i can order one and let you know..trying to keep a straight face here...how long it is
To sum it up, it's huge. Holy cow!
- Card Length
356.1mm x 150.1mm x 71.4mm / 14" x 5.9" x 2.8"
Who said I was going to put 2 in that MB?how you gonna fit 2 4090s on that? unless you use riser cables and mount them above the board. I was actually looking at this board
AsRock Rack SPC621D8 ATX Server Motherboard Single Socket P+ (LGA 4189) 3rd Gen Intel® Xeon® Scalable Processors C621A - Newegg.com
Buy AsRock Rack SPC621D8 ATX Server Motherboard Single Socket P+ (LGA 4189) 3rd Gen Intel® Xeon® Scalable Processors C621A with fast shipping and top-rated customer service. Once you know, you Newegg!www.newegg.com
Drill out the rivets on the bottom and top of the drive cage, be sure you remove the MB so as not to get bits of metal on your electronics.I am using a HAF 932 too and if possible I would like to not get a new case. Can you tell me how you removed the hdd cage to make room for the card?
Did you also have to remove the side fan too for the card to fit?
My card is in the 1st PCIe slot, so the fan is not in the way. I'll post pic.Thank you. I noticed that the card you are using is 150mm wide and the case has 172mm clearance. How did you manage to fit the fan?
Could you post the pic if it isn't too much of a hassle?My card is in the 1st PCIe slot, so the fan is not in the way. I'll post pic.
I don't think it's mounted normally, not vertically... so that axis shouldn't matter to case width(?).Could you post the pic if it isn't too much of a hassle?
