- Jun 21, 2002
According to this benchmark https://www.dsogaming.com/pc-performance-analyses/call-of-duty-warzone-pc-performance-analysis/, you won't be likely to benefit from more cores/threads. The CPU used in the test (9900k) does have higher clock speed and instructions per clock (IPC - the amount of work done in a clock cycle), so it's not a perfect comparison, but it definitely seems to be more of a GPU bound situation. Also it took a 2080Ti to run 1080p Ultra above 140fps. I don't have any experience with this site and their reviews / methodology, but appears to be fine.
Here some testing is done on MW, not Warzone (not sure of the differences in performance requirements) but the 2060 Super is only pushing 120fps on 1080p Ultra. https://www.techpowerup.com/review/...re-benchmark-test-performance-analysis/5.html. The 5700Xt did average 140fps, so I imagine turning some settings down you could keep the game above 140fps or close to that. Again not sure of the differences as comparing the two different sites Warzone seems to have lower performance. Also not trying to recommend purchasing a card based on a single review, but the 5700XT is well within your budget https://www.newegg.com/sapphire-rad...=5700xt-_-14-202-349-_-Product&quicklink=true
One final test you can do to simulate how high your CPU will go without the graphics bottleneck is to turn the resolution down below 1080 to 720p or even lower. Not for gameplay of course, but just to see at what point the CPU becomes the limiting factor and how many frames it can push.
