- Apr 6, 2002
I just got a samsung 205bw yesterday. It is my first LCD screen as I have been using CRT monitors. I have had my MSI Geforce 6800GT card for about 2.5 years now, and have never had a problem with it. However, the LCD screen has been going blank every once in a while and I am getting artifacts on the screen during normal 2d use. I have tried to overclock the video card in the past and have seen artifacts like this before, but that is normally because I have the video card overclocked too much. To the best of my knowledge I do not have the card overclocked anymore. In the settings panel, the card shows it is sitting at 70 deg C with an ambient temp of 51 deg C which I do not think are any different than they were with the CRT monitor attached.
Back to the screen going blank, I do not think it is a problem with the monitor because when i hit CTRL-ALT-DEL the picture will show back up. Very odd.
So anyway, if anyone has any idea what is going on, please let me know. Thanks.
** edit: i forgot to mention that i am running the lcd on DVI, not analog
** edit #2: yes my card is definitely not overclocked. I forgot that i formatted a few months ago and did not install the coolbits inf, so since then it has never been overclocked. Also, i have a MSI K8N Neo4 Platinum SLI, and I can not figure out for the life of me which "voltage configuration" I am supposed to pick in MBM5. I know that the setup should be a WInbond W83627THF-A, but the voltages don't seem to be shown correctly...and neither does any other config in the drop down window. I know that I have my voltage set to 1.575 in the bios, and it shows my core is running at 1.50 with the winbond selected, which seems reasonable i guess, but it says my 12v+ is 2.18, which if that is true, i don't think my computer should even be running. here is the sysinfo from mbm5 just as reference.
----MBM SYSTEM INFO-----
MBM 5.3.7.0
MBM 5 Core EXE : 5.3.7.0
MBM 5 Core DLL : 5.3.7.0
MBM 5 Settings DLL : 5.3.7.0
MBM 5 Dashboard DLL : 5.3.5.0
MBM 5 Hibernation DLL : 5.0.0.0
MBM 5 Ras DLL : 5.0.0.0
MBM 5 Logger DLL : 5.3.4.0
MBM 5 Mail, FTP and UDP DLL : 5.3.4.0
MBM 5 OSD DLL : 5.0.0.3
MBM 5 ASPI DLL : 5.2.1.0
MBM 5 Heat Up EXE : 5.0.0.0
MBM 5 Wizard : 5.3.5.0
MBMIO DLL : 2.32.64.2
MBMIO Driver : 1.0 built by: WinDDK
DLL Folder Location : C:\Program Files\Motherboard Monitor 5\DLL\
Data Folder Location : C:\Program Files\Motherboard Monitor 5\Data\
Language Folder Location : C:\Program Files\Motherboard Monitor 5\Language\
Log Folder Location (Alarm) : c:\program files\motherboard monitor 5\log\
Log Folder Location (High Low): c:\program files\motherboard monitor 5\log\
Log Folder Location (Interval): c:\program files\motherboard monitor 5\log\
Selected Language : English
Info ChipInfo.ini : 18154 bytes 6/17/2004 4:37:54 PM
Info shdn.ini : 388 bytes 10/12/2000 6:47:06 PM
Info Voltage.ini : 38234 bytes 6/23/2006 12:46:38 AM
Info Language file : 22920 bytes 6/12/2004 9:43:20 AM
Up Time MBM session : 01:00:05:21
Up Time MBM total : 44:02:17:00
------Sensor Chip-------
Main Sensor Chip : Winbond W83627THF-A
SMB Address : $0000
Used Bus : ISA
ISA Address : $0290
-Sensor Chip Selections-
Possible Temp Sensors[2] : WinBond 1
Possible Temp Sensors[3] : WinBond 1 2N3904
Possible Temp Sensors[4] : WinBond 1 Diode
Possible Temp Sensors[5] : WinBond 2
Possible Temp Sensors[6] : WinBond 2 2N3904
Possible Temp Sensors[7] : WinBond 2 Diode
Possible Temp Sensors[8] : WinBond 3
Possible Temp Sensors[9] : WinBond 3 2N3904
Possible Temp Sensors[10] : WinBond 3 Diode
Selected Temp Sensors[1] : WinBond 1 (1)
Selected Temp Sensors[2] : WinBond 2 (3)
Possible Voltage Sensors[2] : MBM Fixed
Selected Voltage Sensors[1] : MBM Fixed (2)
Selected Voltage Sensors[2] : MBM Fixed (2)
Selected Voltage Sensors[3] : MBM Fixed (2)
Selected Voltage Sensors[4] : MBM Fixed (2)
Selected Voltage Sensors[5] : MBM Fixed (2)
Selected Voltage Sensors[6] : MBM Fixed (2)
Selected Voltage Sensors[7] : MBM Fixed (2)
Possible Fan Sensors[2] : W83627THF-A-1
Possible Fan Sensors[3] : W83627THF-A-2
Possible Fan Sensors[4] : W83627THF-A-3
Selected Fan Sensors[1] : W83627THF-A-1 T1 D4 (142)
Selected Fan Sensors[2] : W83627THF-A-2 T1 D4 (143)
Selected Fan Sensors[3] : W83627THF-A-3 T1 D4 (144)
Possible Voltage Sub Types[0] : Winbond W83627THF-A
Possible Voltage Sub Types[1] : Asus P4P800
Possible Voltage Sub Types[2] : ASUS PC-DL
Possible Voltage Sub Types[3] : msi 848p neo
Possible Voltage Sub Types[4] : Asus P4C800 E Deluxe
Possible Voltage Sub Types[5] : MSI MS-6728
Selected Voltage Sub Type : Winbond W83627THF-A (0)
--Sensor Chip Readings--
Temperature Readout[1] : 40
Temperature Readout[2] : 47
Voltage Readout[1] : 1.52
Voltage Readout[2] : 3.28
Voltage Readout[3] : 3.104
Voltage Readout[4] : 4.91904
Voltage Readout[5] : 2.176
Fan Readout[2] : 2743
Fan Readout[3] : 5720
---------System---------
Operating System : Microsoft Windows 2000 (NT 5.0) (Build 2195) Service Pack 4
User : splat
Memory in use : 34%
Total Physical Memory : 1048048 KB
Available Physical Memory : 687016 KB
----------CPU-----------
CPU Speed : 2581 MHz
Nr of CPU's : 1
-------3rd Party--------
ShutDownNow :
----Advanced Settings---
Fan Temp : 0
Custom Temp Table : 0
Startup Delay : 0
2E 4E Enabled : 0
2E Forced : 0
4E Forced : 0
Do Not Reset : 1
SMB Scan Range : $10 - $7F
