In Samsung Magician do the operations Secure Erase and PSID Revert result in the same SSD state (i.e. all data on the SSD erased)? If so what is the difference between them?
Use of Parted Magic to Securely Wipe or Sanitize a SATA/mSATA or NVMe Solid State Drive (SSD) and to unlock the Physical Security Identification (PSID)
Thanks I didn't know parted magic would do this. The description I read of Samsung Magician's PSID Revert stated that the SSD would be erased once the function was initiated.
Parted Magic is included as one of the utilities on the self-booting Ultimate BootCD.
Well... I'm just guessing and may be way off. If you run the PSID, you can then format the entire drive. In doing so, the encryption is lost and therefore the data is not in a usable state but.... the data is there. So to most of us, running the PSID Revert is just as good as wiping the drive but hand that drive to the right person and the data could probably be unencrypted much easier.
Just a guess and again, I could be way off. I didn't feel like reading but felt like posting.
