I'm fairly certain that my Samsung ram when set to the same voltages and timings would easily be able to match any of those kits you linked.
I mean that GEIL 2133 kit is running at 11-11-11-36 @ 1.5v, which seems pretty bad to me. My Sammys do 2000 at 10-10-10-24 @ 1.475v instead of 1.5v, and that with 4 dimms.
The team extreme at 2133 10-10-10-30 is a little better, but I'm still confident my Samsung would easily match them.
And I paid 44$ per kit for my Samsungs, those higher end kits are 50-55$. Almost a 10$ difference, and the timings that I'm seeing on them seem to give the Samsungs a pretty large margin to be able to match them.
The ram is specified to run at 1.35v which is considerably lower than other kits rated for higher speeds. Yes they are not binned but the voltage difference makes up for that because there is lots of room to increase it.
I just gave example that not much more expensive kits are rated @2133 when you don't have to count on luck and are still overclocking higher or with tighter timings.
Team kit is Samsung based but they have quite good selection. Others linked by me are Hynix based and I already saw 2600+ 1.65V on them. Can you make 2600+ 1.65V on your samsungs ?
Most of samsungs in latest kits are scalling about:
1866 9-10-10 1.55V
2133 10-10-11 1.60V or 10-11-11 1.55V
2400 10-10-12 1.65V or 10-12-12 1.55V
2600 10-13-13 1.80V or 10-10-13 1.85V
I didn't say that all are bad. I just said that are overrated as not all can make 2600+, just all who were lucky are posting that info on forums. So yes they are scalling good but till about 2400 and for higher clocks you have to pump high voltage.
You are defending memory that you actually bought without bigger idea what is in other kits.
I say don't judge memory by its label ( you should already know that as your kit is 1600 11-11-11
). You had luck to better chips but are we talking about your kit in this case or overall ?
If we are talking about our own kits then I have Geil Veloce 2133 10-11-11 that cost me ~$50. This memory is in 1.50 and 1.65V versions and is running fully stable
@2600 11-13-12 1.65V and up to 3100 for tests on air ( probably IMC limit ). Similar IC is in GEIL Corsa 2133 11-11-11 and in 2400 11-11-11. You can also find it in some 2600+ kits. G.Skill ARES linked in last post can make something similar as it could make
2400 10-12-11 1.65V ( so should make about the same as my Geil ).
Other thing is that to make Samsungs fast you have to play with sub timings. Most samsung kits have really bad spd that let them make higher clocks on lower voltage but are slower on auto settings than most other IC ( so count that's Hynix as not much more left on market ).
Especially on latest Intel platforms main timings are not most important.
Here is my Geil Veloce 2133 review that includes TridentX 2400 10-12-12 Samsung IC kit results and in almost all tests Geil is beating G.Skill even on lower clock with the same CL. You can also check my
IB memory guide for some similar results.
So again I'm not saying that these Samsungs are bad or don't buy them but that there is more kits on market worth to check before you decide to buy something especially that prices dropped for all other kits but not much for these Green Samsung series.
These samsungs were one of cheapest good clocking kits available for some time but now there is more cheap kits and don't start with $5 difference because it's not even funny when we are talking about memory that will be working on ~$380 board.
