- Oct 9, 2001
- Dundalk, Ireland
Hey all,
Did a search for this and came up with nothing.
Just bought a Sapphire 9800 Pro , and can't for the life of me connect it to a TV or another monitor. Below are pictures of the Display options.
http://www.angelfire.com/alt/cpucooling/Display1.JPG
http://www.angelfire.com/alt/cpucooling/Display2.JPG
Apparently, according to the manual, you simply click the circled button on any of the devices, when you have connected the card to a TV or LCD Monitor etc, and the connected device is activated.
But my damn card doesn't even let you click any of the other option except for the connected monitor. All other options are greyed out. What the hell? Even when you change the scheme nothing happens.
And what's the other option on the second picture, the secondary display? I've tryed selecting it and then connecting to a TV and a monitor but theres no change.
It's completely baffling. (By the way, when I say connect to monitor, i mean using the DVI to 15pin adapter that came with the card).
Any help much appreciated.
Thanks!
Thanks!
