SATA port (provided by C602 chipset) not recognized in Windows 10
mrjayviper
problem: Devices connected to the 2nd SATA port is not recognized in Windows10.
some info:
  • HP Z820 desktop with 2 SATA ports (from Intel chipset) + 4 SCU SATA ports (from chipset and unused) + 8 SATA ports from an LSI chip (I got no idea what SCU means)
  • I am not experiencing issues with the 1st SATA port. I can see any device connected to the 1st SATA port.
  • Both ports (and the connected devices) are recognized and usable in Manjaro (installed on a separate SSD)
  • The HDD is formatted as NTFS.
Test I've done/things I've checked:
  • In the BIOS, the connected HDD shows up (connected to the 2nd SATA port). I also have a BDROM in the first SATA port.
  • With my HDD not showing up in Windows, I've looked at Device Manager in Windows10 but there are no errors/issues there.
  • I've swapped my BDROM and HDD. Both still shows up in the BIOS. But the BDROM has disappeared from Windows while the HDD showed up in Windows.
  • As another test, I've connected my SSD (containing Manjaro at the moment) on the 1st SATA port and connected the HDD on the 2nd SATA port. I can see both disks when I booted into Manjaro/Linux. I can even mount the HDD (read only) inside Linux.
  • I have no issues with any HDDs when connected to the SATA ports provided by the LSI chip (IT-mode).
Any ideas? Thanks!
Sounds like a port is bad. Why it's showing up in the BIOS and not Windows I don't know.. the HDD is initialized, right? It isn't new?
I had to look up your other OS but reading your trouble shooting, my question was answered.
I would uninstall/reinstall any and all chipset drivers. Update the BIOS/UEFI and see where that takes you. This sounds like it is clearly a Windows issue and not hardware to me.
some info:
Any ideas? Thanks!
A HP Z820 is a server not a desktop :) From what I have found, SCU could stand for SAS Control Unit, so you may need a special cable for those ports. Contact HP and see if you can get the cables for that.
