I have an ROG Strix B550-f Gaming board and just started to have severe USB issues on all ports. I've read back in the spring and summer about the USB connectivity issues plaquing the B550 and 570 boards, but I never had an issue. I'm on the current BIOS which was suppose to fix the issue and tried all other BIOS settings to rectify, but nothing.
I'll plug in a USB stick and it will work for 30seconds, disconnect and windows throws an error saying something is wrong with the USB. It will not work again until I reboot the computer.
I have an external SATA that isn't working either, and even if I plug in my XBOX controller it shows up in Device manager, but will not power on.
I tried a PCIe USB card thinking it was the USB"s on the motherboard, but I'm having the exact same issue, if not worse. I also noticed when I disable the onboard USB ports, it also disables blue tooth. Should this be the case?
I tried a fresh install of Windows with the same result. Any ideas? Is the board toast? Everything else works great, no blue screens or anything. Is it possible it's the PSU? Not enough power suddenly?
Ryzen 3700x
ROG Strix B550-F Gaming Wifi
32gb DDR4 3600
Radeon 5700xt
Corsair 850W PSU
Any help would be really appreciated!
I should add that most of my devices are on a powered USB hub, but plugging directly into the PC causes the same problems.
In doing some more troubleshooting, it looks like the issue is worse off the new PCIe card.
All devices are plugged into a powered USB hub, but I found the following.
Xbox controller or mouse do not work when the hub is plugged into the PCIe card. Mouse also randomly freezes when wireless.
The controller and mouse work fine when plugged into the hub from the onboard USB ports.
Is it possible that the PSU isn't cutting now that the issue seems work when it has to power the PCIe USB card?
All components are about a year old, except for the PSU which is a good 10 years. To my understanding 850W is more then enough to power this. I'd just hate to throw money at a new PSU and have it do the same thing. I'd also hate to replace the motherboard and have it be the PSU.
Again, everything else works great. I've never had a single issue with any games, and the PC doesn't even blue screen.
Ryzen 3700x
32gb DDR4 3600
Radeon 5700xt
Corsair 850W PSU
