Well , I'm on a tiny fixed army disability . I'm doing this build mostly with barter . Please excuse me if I use wrong comp terms as I have shrapnel in my brain and have memory / learning nomenclature problems , and frequent severe migraines .
I'm currently using 2 comps , one old one I refurbished and one built .
Refurbished comp - Compac dual core AMD , windows 7 Found this comp sitting in front of a dumpster in the rain a few years ago and I refurbished it and ditched the vista for 7 . This comp cost me $ 55 for the windows 7 and I loved messing with it and it gave me the bug to start building comps . I have about 2500 hours on it .
and this one
Antec tower with 5 giant fans
Gigabyte mb G31M-ES2L
INTEL CORE 2 CPU 6700 RUNNING 2.66GHZ
WESTERN DIGITAL 500GB HD
2 GB RAM
WIFI CARD
vid card but I don't know what it is lol
Windows 7 Ultimate / UBUNTU 12.04 LTS PRECISE PANGOLIN
This comp cost me $ 150 and a lot of bartering . I have about 400 hours on it .
I'm using an External 1tb hd storage
and a 37 " Vizio hd tv as a monitor , and a 32" 3D processing monitor with a switch .
I'm using a 2 port kvm switch to run both comps .
Everything is plugged into 2 Ditek battery backup/surge protectors .
I do not game but I draw/write graphic novels on the comp and am working on an anime series with my friend Ken Yamata from Tokyo . I spend a lot of time on TOR and do """ anonymous """ stuff . I DL and watch a lot of movies . I also make extra $ on fleabay and craigslist to get by .
While I do not game I use stuff like Kompi Animated Video Lab Suite , Maxon Cinema 4D suite with a bunch of tools and add ons from Biomekk , UNITY 3D , Vue 11 xStream pro , Carbon Scatter 2 , InterPoser Pro , Drop It! Pro , Oxone 6 , Adobe photoshop and Adobe Master Creative Suite , Adobe Air , etc , hence the new build as both of my comps are not up to snuff for the things I do and I can't use some of my software or parts of some of them . . I also have a 37" HD TV for a monitor and love to watch movies and TV on it so I want to get the best picture out of it .
So far I have aquired the following stuff mostly by barter .
2 cases I can use
Either - older but sweet AlienWare full tower with 7 small fans or a Thermaltake full tower with 7 giant fans .
MB - Asrock 970 extreme 3
CPU - AMD FD6100WMGUSBX FX-6100 Six Core, 8MB L3 Cache, 6MB L2 Cache, 3.30GHz (3.90GHz Max Turbo), Socket AM3+, 95W, Unlocked
2 HDs - Western Digital Cavier Blue 500gb hd and a Western Digital 750 gb
RAM - 6 gb 3 x 2 gb OCZ ddr3 dimm 240 12800
PSU - Aspire ATX 500w turbo see thru case with 2 blue led fans , fan speed adjuster . This came with the Alienware tower , and I have had it inspected and tested .
LG super dvdrw lightscribe X 2
I'll be using a NEC X462UN MultiSync 46" Large LCD that I traded a Triumph bobber chopper for and my Vizio 37" hdtv , and a 32" 3D processing monitor , so will need to run all 3 monitors simultainiously .
I also have an external 1 tb hd storage
So as far as I can tell by searching online all this will work together . I need opinions first on my parts , keeping in mind that sadly I live on a very very tight budget .
My worrys -
# 1 - that the psu while being very highly rated at the time and testing out awesome , being quite old I will not be able to hook it up to the modern stuff or it will not be as capable as a newer one . But man you should see how sweet it is with huge heat sinks .
# 2 - I do not have the software/cd for the Asrock 970 extreme 3
# 3 - I need recomdations for a common video card to pick up used that will work well with this build and my hd monitor . I find all the info on video cards confusing and after reading tons of posts all over the internet ( they mostly dissagree with each other ) I'm lost .
# 4 - Same thing with a sound card . I have six speakers running currently 3 sets . I want to get a 7.1 speaker system . So I need recomdations for a common sound card to pick up used that will work well with this build .
# 5 - what is the cheapest but nicely performing blueray player to install in this build .
Any opinions or advise will be greatly apreciated .
and this one
2 GB RAM
WIFI CARD
2 cases I can use
My worrys -
