- Jul 30, 2014
Hi guys,
Looking at getting myself this system for my home https://www.aliexpress.com/item/ZOS...783498241.html?spm=2114.search0104.0.0.PGMj3g
I have my 1x ADSL modem/router in main room and I would like to know how I would go about setting this up (I think I know but I want to check)
I have another spare wireless modem which I plan to hopefully make this system wireless from the roof.
I will have the 4 cameras which will be directly hooked into the DVR via lan/ethernet/cat5 then one lan/ethernet/cat5 directly into my extra modem/router witch as mentioned should hopefully be able to connect on my network wirelessly should I need to gain access to the data stored on the HDD in the NVR
I will then put the extra modem/router thats in me roof into a mode to wirelessly transmit on my network (for the purpose of accessing the cameras via internet should I need to (otherwise everything recorded to DVR) is this putting it into ap mode or a bridge? just not sure on the specifics name wise
I want to know;
1) Will this setup work? (as I am pretty sure there is a power point in the roof)
2) Will any 1tb hdd work in this system or do I need a certain make/model?
3) Does anyone know know of a good free CCTV software I could use in conjunction with this NVR/system so I can access my cameras on iphone/android or via webbrowser?
Cheers,
Bandit
I want to know;
Cheers,
Bandit
