Makes XP no longer treacherous:
Requires 2 blank CD-Rs.
nLite 1.4.9.1:
http://nliteos.com
With nLite, first make a CD with service pack 3 integrated.
After the first CD's burned, wipe the HDD and reinstall XP from the CD you just created.
Then redownload nLite:
Before running nLite from the SP3-integrated CD, go here:
http://xdot.tk/updates.html
This will add all updates for SP3!
Now, insert the CD with SP3 integrated then run nLite.
Add the hotfixes to the add-ons-and-update-packs section.
Don't forget to have nLite make an ISO!
The second CD is for SP3 and all critical hotfixes.
You can also use nLite to have XP include Intel AHCI and RAID support!
