- May 17, 2005
- High Desert, Calif.
- Thread Starter
- #21
Very cool. I've actually have a Dell Poweredge 2950 and R410 that I'm using as workstations because they were dirt cheap.
Video cards for servers as you have discovered is a challenge. There actually is an x8 version of the gt710 by evga, and zotec makes a x1 version of the gt520. Sadly, neither of these made the video on either server faster. In the end the only video upgrade I used was an old gt610 in the r410 since it has an x16 slot.
One idea for your server is if you use a low profile video card. Then you could just screw it into the stock slot. I wouldn't worry too much about the card bending when in a horizontal position as back in the day most long ISA cards (longer than most cards today) didn't reach the support at the end and would hang like that. Of course, the slot on the motherboard was really holding it in, so that's a big difference. But if you had a custom bracket, the 'tab' on the end would go in slot on the case and with the retaining screw, should provide a decent amount of support.
Glad you got something sorted. Was the performance of the 710 good? I didn't really see a positive change in either of my Dells with the 710.
Dooo itttt!!!I'm using the 710 as a basic display adaptor, although I would like to see what it's 192 CUDA cores are capable of.
resurrecting old thread i know, buuuuuuut, how quiet were these particular coolers? im in the market and trying to decide if i wanna get something specific to 2011 or if something like the hyper 212+ would be fine.... the quieter the better.
p.s. only reson i res'd the thread is i know the user is still active on the forums
