- Feb 21, 2008
- Baltimore, MD
After building my new plex server I had some leftover stuff, and combined with some other leftover parts i was able to put together a decent server.
Not sure what i'll do with it yet. maybe use is for some video encoding (after a CPU upgrade) or temporarily donate it to my dad's SETI farm until i find something to do with it.
Specs:
Best Buy Rocketfish (Lian Li rebadge) case that i've had for years collecting dust from an old watercooled build.
leftover Supermicro X9DRi-LN4F+ motherboard (it only takes a V1 chips and i wanted to use V2s for my plex server)
2x Xeon E5-2650L 1.8GHz 8-core (came with the plex server that i swapped out)
2x CoolerMaster Hyper 212 evo (leftover from old mining rigs)
32GB Samsung DDR3-1333 (pulled from backup plex server)
160GB Intel 320 SSD (from backup plex server)
WD 1TB Black HDD
PCP&C Silencer MKIII 1200w (dad had lying around from troubleshooting some server issues)
2x Scythe 120x38mm 2000rpm fans for intake
4x 120x25mm fans on exhaust
To fit the motherboard, i had to re-drill some standoffs. the board is listed by Supermicro as "Enhanced E-ATX". luckily the case has plenty of room to fit the taller MB. The bottom 6 standoffs lined up, but i had to redrill the upper 6 ones. luckily it was pretty easy, and the lower 6 helped me line it all up perfectly. I had also already cut the holes in the front and top for the additional fans.
when i was swapping the MB in the plex server, i wasnt careful enough and slightly bent a CPU pin. i VERY careful tried to bend it back, but i was too scared to break it so its still a little bent. I was worried that it wouldnt work, but i fired it up last night and its working! woohoo!
Specs:
WD 1TB Black HDD
