- Sep 12, 2015
- San Antonio, TX *aka hellsville*
lol.
I have a couple IDE 40mb drives somewhere..........if you wanna talk old.
lol.
Bios glitch. Replace the battery and re-flash the bios.
Memtest your ram.
http://b2b.gigabyte.com/products/product-page.aspx?pid=992#biosLink the bios and let me look at it for you.
Rats. That's what I figured anyway. It's a server after all.Nothing unlockable there. Bios options are pretty bare bones.
A few. I've been doing this a long long time.Surprised you were able to get into the BIOS. Got some tricks up your sleeve eh?
Ecc isn't a catch all. You'll have to replace it.
I don't know what to do at this point.
The 2 Micron sticks are fine. The 2 Infinieon sticks are fine.
Tested the micron's in the first 2 slots, and the infineions in the 2nd and 4th slot.
Yet when all 4 are installed, memtest finds errors. wtf?
What is this supposed to mean??
motherboard or cpu doesnt like 4 sticks. Hard to narrow which though.
Hmmm you bring up a good point Evilsizer.on something this old the cpu doesnt care how many sticks, its the NB. though silver this is why people say use the same brand and model, i think as long as the IC's on the sticks are the same you should be fine. there could be some sub timing issues between the two that you just cant change to fix it. i would just track down two more micron sticks for the server.
I'll test one Micron and one infineon stick. Maybe it will error out?
At least these are 1Gb sticks.
possibly more ram voltage if you can, i dought there is an option but more chipset voltage would help too.
on another thought, replace the tim under the NB heatsink and/or the heatsink as well for better cooling or just add a small fan if you have one.
