- Feb 11, 2006
- top gear
- Thread Starter
- #21
killercanadian said:lead, £200 will buy a heck of allot of water cooling.
ThermoChill PA120.3 120mm Triple Radiator £48.50 ex VAT
Danger Den DDC 12 Volt Rev2 Pump £47.49 ex VAT
Swiftech MCRES Micro Reservoir £9.99 ex VAT
Swiftech Apogee GT Extreme Performance CPU Water Block £31.95 ex VAT
Tygon R3603 Tubing 1/2" ID 3/4" OD (Per Foot) £1.79 ex VAT
Zalman ZM-F3 120mm Silent Case Fan £5.49 ex VAT x3
the parts i listed are some of the best available, and its still under £200
its not terribly difficult to build a damn good w/c system for that kind of money.
*edit* could not find Swiftech Rad box on Thecoolingshop.com so you will still need one of those depending on your case.
KC
thanks for your time. Isnt the 'rad box' just a stand off for the radiator from the back of the case, i could probably make one if so
