- Nov 13, 2003
- Westminster, CA
Is it true that having two fans in a push/pull configuration can eliminate dead spots -> no shroud needed? Post some pics people.
i am nude said:it makes me wonder if having a "push" fan really does anything signifigant, or if it's just for looks
EluSiOn said:
coz that side was... cold air pull from outside the case and push to the heater core...
[/B][/QUOTE]
Thats what I meant when I said push... Pushing air on to the core. Not pulling air away from the core
Soja said:Nah, these shrouds are a bit small for procores:
You should try using a filter at the intake. Prevents having to dissemble the shrouds to clean.
Soja said:You should try using a filter at the intake. Prevents having to dissemble the shrouds to clean.
