- Mar 24, 2015
As the title says, my PC will no longer turn on. Today is the only time I have seen any issues from it like this. It would turn off during a game, presumably once power usage ramps up. I lowered my GPU power usage and overclocks as well as lowering my CPU overclock. Now the symptoms are: 5V power, and then the fan lights and disk drive light will flicker when I flip the switch, let the power drain, then turn it on and press the on button.
I believe this is a power supply issue. What are your thoughts?
I have taken out the GPU. The system will turn on without the GPU, but once it is put back in the problem returns. Either this means the power supply cannot take the extra usage from the GPU or that the GPU is dead. I ran the CPU at 100% for a while and the system stayed on just fine.
How do I test if a GPU is dead?
